Question New problem with 1.0.8
17 years 9 months ago #4374 by pequeno74
Replied by pequeno74 on topic Re:New problem with 1.0.8
Many thanks Lintzy
Works fine for me!!!
And it´s a neccesary fix!
17 years 9 months ago #4377 by Matias
Replied by Matias on topic Re:New problem with 1.0.8
Thanks!
We will not fix any non critical bugs for 1.0.x, but maybe for the next version..
17 years 9 months ago #4405 by pequeno74
Matias wrote:
Thanks!
Thanks Matias, and thanks to all the developers Kunene for the work you are doing.
17 years 8 months ago #7103 by rinuccio
Replied by rinuccio on topic Re:New problem with 1.0.8
Kunena 1.0.9
22-February-2009 Matias
# [#15157] Empty messages in Joomla 1.0 part 2
# [#15170] Add backward compability to FB 1.0.5: Same meaning for 0 in latestcategory
21-February-2009 Matias
# [#15162] Two same smileys in a row do not work
# [#15163] Fetch Kunena template from Joomla theme fails with warnings
20-Februray-2009 fxstein
# [#15151] Ensure fbConfig is array during legacy config file write - Thx JoniJnm!
20-February-2009 Matias
# [#15148] Post emails for moderators: name missing
# [#15150] Don't send email to banned users
19-Februray-2009 fxstein
# Incorrect permissions handling fixed
19-Februray-2009 Matias
# Search: Fixed SEF/no SEF issues. Pagination and links should now work for all
# Pathway: comma (,) was missing between usernames if there were no guests
# Thread View: Minor fix in pagination
18-Februray-2009 Matias
# Broke PHP4 compability, added emulation for htmlspecialchars_decode()
# Pathway: removed multiple instances of one user, use alphabetical order
Ehm...
In this post I have solved two problems in the template default_ex
These corrections will be applied in the new 1.0.9 release? :) :) :) :) :) :)
17 years 8 months ago #7404 by Matias
Yes, they are in 1.0.9. You can try to apply the changes by yourself (from SVN) as they are small ones..
17 years 7 months ago - 17 years 7 months ago #11321 by pequeno74
The correction of Lintzy works fine in 1.08 but No in 1.0.9.
K1.0.9 are the same problem.
Someone know the fix for K1.0.9?
Last edit: 17 years 7 months ago by pequeno74.
