Question Formatting Problem
17 years 4 months ago #23024 by jgartmann
Formatting Problem was created by jgartmann
I need help fixing a formatting problem. Dont even know where to begin. Take a look.
www.jmkac.org/component/option,com_kunena/Itemid,1002/
How do I fix the width of the first column?
17 years 4 months ago #23057 by sozzled
Replied by sozzled on topic Re:Formatting Problem
I would begin by using the original default_ex template that came with your installation kit.
What version of Joomla are you using? Are you using any third-party SEF components (like sh404SEF, for example)?
17 years 4 months ago #23086 by Lintzy
Replied by Lintzy on topic Re:Formatting Problem
It is recommend to use the template default_ex.
But if you want to use Template default furthermore, you can fix this formatting problem, with editing kunena.forum.css
and set this code into the kunena.forum.css (components/com_kunena/template/default)
#Kunena td { width:auto; }
17 years 4 months ago #23159 by jgartmann
Replied by jgartmann on topic Re:Formatting Problem
I am using Joomla! 1.0.15 Stable, Kunena 1.0.10, and sh404SEF. I have just switched from Default to default_ex with no change. I just need to shrink the size of the first column and I cant find where to do it.
What effect does a third-party SEF component have?
17 years 4 months ago #23160 by Lintzy
Please insert the code, that I posted into kunena.forum.css.
It has nothing to do with SEF, it is a CSS problem.
17 years 4 months ago #23163 by jgartmann
The code worked perfect thank you Lintzy. Much love!
