Question Kunena 1.9.0b a J 1.5.10 BB code fronted
17 years 6 months ago - 17 years 6 months ago #14751 by Daviscopperfield
Hey people do not know why in the kuneně when writing the new panel does not work with úpravama? It only hold a spoiler for the rest of eBay\\\'s writes \\\"The adjustments may be used only on selected text!\\\" - When you write some text and finger panel adjustment does not respond. as well as not add emoticons. If someone you know please what to do with it. pioraďte - Thanks a lot. Source site HERE
out panel BB Code :(
Last edit: 17 years 6 months ago by Daviscopperfield.
17 years 6 months ago - 17 years 6 months ago #14752 by Daviscopperfield
hello remains under panel BB code this text: Adjustments may be used only on selected text!
And we still can not insert bb code - only ebay spolier and video.
Help please thank you
I speak Austrian German, Czech, and Canadian English using Google reloading ;)
17 years 6 months ago - 17 years 6 months ago #14778 by svanschu
The problem occured from some JS problems on your site. JS Problems can come from Modul or plugins you installed using JS...To detect the source of problem, you have to deaktivate all moduls using JS as well and test it again.
Last edit: 17 years 6 months ago by svanschu.
17 years 6 months ago #14817 by Daviscopperfield
Hi, thanks for the advice - I turned off all the modules and script, I set the default template but it does continue. But thanks for the tip. Nice day. :-)
17 years 6 months ago #14820 by grumblemarc
RokCandy. Do you have this installed and enabled. Yvcomment? Anything with it's own BBcode?
17 years 6 months ago #14832 by Daviscopperfield
Dobrý den, ano způsobil to zásuvný modul rock candy - system, když ho vypnu panel je v pořádku. Problém je to, že když vypnu zásuvný modul - članky nejsou dobrý, protože to rozhodí template. To bude asi problem všech šablon od rocktheme, protože mají v sobě zabudovanou komponentu rock candy. zajímavé je, že zapnutá rock candy nemá vliv na BBcode joomla coments, ale kunenu to zablokuje.
S pozdravem David Prchal a děkuji.
Hello, yes it has a plug-rock candy - system, when you off panel is in order. The problem is that when you plug-off - articles are not good, because this decision template. This will be a problem all templates from rocktheme because they have built in a component of rock candy. interesting is that it is on rock candy does not affect the BBCode Joomla coments, but kunenu to hang.
Yours sincerely, David Prchal, and thank you.
