Question Varying Width
17 years 7 months ago #12926 by mjanzen128
Replied by mjanzen128 on topic Re:Varying Width
It could also be a template content width issue.
If so, I had this problem once when I made the template I chose smaller in width. You just have to lower other content based widths within the CSS of the Joomla template. It should fix it. Play around with the width parts of the css, see what happens... but, just backup the CSS file first.
17 years 7 months ago #12993 by ruimanuel
Replied by ruimanuel on topic Re:Varying Width
thanks Lintzy and mjanzen128
I will proceed as you told me, testing first with a standart theme and with all the modules unpublished.
great support!
17 years 6 months ago #14319 by YeeP
Replied by YeeP on topic Re:Varying Width
How about making this width fluid with percentages? Then it would adapt to any table width or screen resolution.
I will see if I can do it when I have some time.
17 years 6 months ago #14322 by Lintzy
Replied by Lintzy on topic Re:Varying Width
The problem is, if the Joomla Template has a width of 100 % and the Kunena template has a width of 100 % (or 90 % or so) and you have users with a great monitor solution, Kunena does not look good ;).
The best solution is a max-width and min-width (in pixels, so you have a control over the look of the forum)... imho ;)
17 years 6 months ago #14324 by YeeP
Thats cool. I have multiple problems on my page because of lack of fluidness. I will have to put up a backup and make it real wide to see it. Part of the problems without the width I would like include: narrow image sizes and useless space on the outside of the forum. Personally, I like to use as much real estate as possible. Obviously, this is just my opinion. :)
17 years 6 months ago #14356 by Lintzy
There is no "allround-solution". Fixed and fluid widths have their advantages and disadvantages. I wrote: "If the Joomla-Teamplate has a fluid width and if Kunena Template has it too" ;)
