Question adjust width of Quick Reply box?
17 years 7 months ago #10087 by bytebandit01
i've tried using all the available kunena templates (default, default_gray.. and even default_ex) and all of them show the same result..
the width of the quick reply box is is to large.. making it too close to the column border.
the same also goes to other user contributed templates like numinu_ex and default_ex_creme..
but here in kunena.com.. quick reply box is displayed fine with a space before the column border..
with these.. i am suspecting that it is my template that is causing this..
i just don't know what css property to look.. :( need help.. thanks..
17 years 7 months ago #10093 by nzjacob
What Template are you using for the Site ?
Joomla version info ?
Need more detail to be any help
17 years 7 months ago #10242 by Lintzy
Edit the kunena.forum.css of your chosen template, search the string
div.fb_smalltext
and put in, the width you need, perhaps (of course you can change the value)
div.switchcontent { width:90%; }
or
div.switchcontent { width:400px; }
17 years 7 months ago #10261 by bytebandit01
div.fb_smalltext
or
thanks Lintzy. i used width:99% and it solved my problem. thank you again ;)
