Question SOLVEDGodaddy php timeout
17 years 7 months ago - 17 years 7 months ago #9949 by reelly
OK I have been trying to get this loaded for two days. I had Fireboard but wante to try Kunena. However just the same as others I am getting the PHP timeout errors. Site is www.outboarddrag.com . Joomla 1.05, MySQL 5.0. With no help from Godaddy, they said they have no control over it. I have chnaged my php.ini file with the information provided here docs.kunena.com/index.php/Technical_Requirements Still no luck. The settings do not change.
I have tried to upload the files to the server via FTP and then load directly from server but always get "Please enter a package directory". I have tried it unarchived and still in zip format. no luck.
I have searched through threads but did not see any updates from folks with same issue. Did you guys figure it out or what? Thanks!
Tired of beating my head against the wall.
Last edit: 17 years 7 months ago by reelly.
17 years 7 months ago #9966 by core2
Replied by core2 on topic Re:Godaddy php timeout
First of all if you are running Joomla 1.0.5 you must update to latest version 1.0.15!
Most hosting provider restrict which php settings you are allowed to override.
I think the way forward for you still is a install form local directory. You have to figure out which directory you can install from. Some have success with /tmp others reports using path_to_my_joomla_install/tmp (aka the joomla temp directory)
Hope you are able to do a successful install because Kunena is great!
Visit the Kunena documantation .
17 years 7 months ago #9972 by grumblemarc
Replied by grumblemarc on topic Re:Godaddy php timeout
Familiarize yourself with Joomlapack and a local testing environment. You can create your Joomla install locally and upload/install it as a Joomlapack archive via Kickstart in less than 20 minutes. This will bypass any server timeouts.
17 years 7 months ago #9973 by reelly
Replied by reelly on topic Re:Godaddy php timeout
cool thanks guys! For anybody else with the same issue I could istal it from directory if i placed the package in the Joomla tmp folder. I am up and going now Thanks!
17 years 7 months ago #9975 by grumblemarc
Good. It got so bad that even that wouldn't work for me. I had to move hosts.
17 years 7 months ago #9982 by bytebandit01
Replied by bytebandit01 on topic Re:Godaddy php timeout
i have been with godaddy for my j1.0 and j1.5 sites.. kunena seemed to have worked for me though.. yet i havent done any special configuration..
