Question Fireboard 1.0.5RC2 - Remove Sample Data Error
17 years 8 months ago #963 by rhys_daniels
Ok cheers Jd, i understand
17 years 8 months ago #967 by grumblemarc
I guess I misunderstood this time. I rarely have used that option. I'll try to remember that.
17 years 8 months ago #972 by Philip Roy
On a related side note...could the load and removal of sample data links be tucked away somewhere a bit less prominent? Or perhaps have multiple warnings? I've had a couple of instances where I've been half asleep and almost hit those buttons and ignored alerts.
I know...my bad...but the links are quite prominent. I wonder if it could be part of the install process instead?
Just a thought.
Phil
17 years 8 months ago #3300 by rhys_daniels
rhys_daniels wrote:
Currently having a problem removing the sample data from the FireBoard forum. It does remove some of the data but also returns a error message(s),
Ive attached a screenshot of the problems. Take a look.
Know the fix?
+ Open admin.fireboard.php file in administrator\components\com_kunena folder, at about line 1394, find following code section:
// Remove Sample Messages Text
$database->setQuery("DELETE FROM #__fb_messages_text WHERE id = 1");
and change to:
$database->setQuery("DELETE FROM #__fb_messages_text WHERE mesid = 1");
17 years 8 months ago #3346 by Matias
DO NOT DO THAT!
Removing sample data may corrupt your forum. Fre broken feature has been removed from Kunena 1.0.8
