Question Error installing Kunena, search not working
for more information, i tried to install Kunena v1.5.0a for the comparison, and it's work...but when i try install v1.0.8 that's can not work either...
You get error message during install about legacy mode? That error does not come from Kunena, it comes from Joomla. It looks like that you haven't enabled legacy, or it's not working as it should because of some third party module..
Kunena 1.5.1 Beta is out and it works better than 1.5.0 Alpha. But there are still many broken features, both in backend and frontend..
so what you suggest to me for solve this problem...do i must re-install my joomla ? because it's all ready on live site...
thank you
the others site of mine can't install kunena 1.0.9 too
* JFTP::mkdir: Bad response
* JFTP::chmod: Bad response
* JFTP::store: Bad response
* Warning! Failed to move file.
just for information that's site used standard joomla 1.5.10,
Also remember that if you have same name and different passwords (for example your user in Joomla is yoggiesd and your ftp user is the same), you need to enter the right password every time you save the configuration. This is because of browsers save only one password for each site..
i always install the components from joomla backend
can i install the component manually ?
* JFolder::create: Could not create directory
this message when i not enabling the ftp.
do i must change chmod folder ?
