Question Problem with installation
17 years 8 months ago - 17 years 8 months ago #7764 by Takamunga
my installation ends with this screen.
Nothing else happen and kunena is not working.
Thx for reply.
Last edit: 17 years 8 months ago by Takamunga.
17 years 8 months ago - 17 years 8 months ago #7773 by core2
Replied by core2 on topic Re:Problem with installation
Please give some more information. Do you meet the technical requierment? This may be to a timeout. Try to increase your php-setting. Have a look at docs.kunena.com/index.php/Technical_Requirements
Pleas fill in:
Joomla version:
Kunena version:
(Fireboard version:)
php version:
mysql server version:
php max_execution_time :
php memory_limit :
safe_mode :
Visit the Kunena documantation .
Last edit: 17 years 8 months ago by core2.
17 years 8 months ago #7783 by Takamunga
Here it is:
Joomla version: 1.5.9
Kunena version: latest 1.0.8
php version: 5.2.5
mysql server version: 5.0.51
php max_execution_time : 30 ( max 60 on my tarif / hosting )
php memory_limit : 32 M
safe_mode : OFF
17 years 8 months ago #7785 by spacereactor
One way to short the install time is upload kunena component to your server joomla tmp folder first, and Install from URL OR increase your php-setting.
17 years 8 months ago #7797 by core2
Takamunga wrote:
Here it is:
Takamunga, hopfully you have read the technical requirement and understand where your problem is...
17 years 8 months ago #8263 by lightinthedark
I found a solution that worked for me in the same situation (unable to modify my host's php.ini file). It's posted at www.kunena.com/forum?func=view&catid=16&id=1447
Hello
:-Dave
