Question Forum set to Author level (or higher) invisible..?
17 years 8 months ago #7208 by MagnusL
Hi!
I just installed Kenena as an upgrade of a Fireboard forum on a Joomla 1.5.9 installation. Joomla here have the following access levels:
Registered
Author
Editor
Publisher
And the categories and fora in Kunena can be set to:
Everybody
All registered
Registered
Author
Editor
Publisher
However, setting a category and fora in Kunena to any level higher than "All registered" makes it invisible to all users, except admin. That is, even when I have access level Publicits, I cannot as a user see a forum set to level Author or Editor. The only way to make fora accessible is to set them to "All registered".
This means that I cannot differentiate the access level, which is critical for my community.
Anyone got advice on what to check or to do?
Magnus Larsson
17 years 8 months ago #7211 by Mr Livered
I don't have the solution but FWIW it works OK on my site (also 1.5.9 and 1.0.8) so presumably not a problem within Kunena.
