Question Errors after migration von joomla 1.0.14 and Fireboard
17 years 8 months ago #7022 by boliviano
I migrated from joomla 1.0.14 to joomla 1.5.9 and everything works just fine besides the kunena forum which I updated from fireboard 1.0.4. I migrated all data like writen in the fireboard forum. In the kunena backend I can see my all my categories and statictics which are fine but if i go to Kunena Forum Administration - i get the following error:
Fatal error: Unable to load moderator list.\nDB function reports no errors in /home/ikebanak/public_html/mytrainee2/components/com_kunena/lib/kunena.debug.php on line 54
in the front end i get this error:
Fatal error: Unable to load messages.\nDB function reports no errors in /home/ikebanak/public_html/mytrainee2/components/com_kunena/lib/kunena.debug.php on line 54
you can take a look here:
www.ikebana-keramik.com/mytrainee2/trainee-forum.html
I would be grateful for any help.
Thanx
Sascha
Information about my Server:
PHP-Version: 5.2.6
Webserver: Apache/1.3.41 (Unix) mod_gzip/1.3.26.1a mod_log_bytes/1.2 mod_bwlimited/1.4 mod_auth_passthrough/1.8 FrontPage/5.0.2.2635 mod_ssl/2.8.31 OpenSSL/0.9.8b
PHP-Anbindung zum Webserver: cgi
Joomla!-Version: Joomla! 1.5.9 Production/Stable [ Vatani ] 9-January-2009 23:00 GMT
17 years 8 months ago #7028 by core2
Did your fireboard work on Jommla 1.5.9?
Visit the Kunena documantation .
17 years 8 months ago #7035 by Matias
You may have missing tables in you Joomla installation. Check if you have jos_fb_messages and jos_fb_moderation.
17 years 8 months ago #7044 by boliviano
hey matias, hi core2,
i have not tried fireboard in the new joomla installation. So i dont know if it would have worked.
i have jos_fb_messages but jos_fb_moderation is missing.
how can I reconstruct this table?
17 years 8 months ago #7395 by Matias
Can you copy it from your old installation? You should check that you have all jos_fb_ tables in both installations.
Try to uninstall and install Kunena. Do you get success in the installation?
