Question Converting IPB to Kunena
17 years 9 months ago #617 by Zoolge
Is there a way to convert a IPB forum ( www.invisionpower.com/community/board/index.html ) to Kunena. As I really want to move to Kunena but cant if I dont know how to convert my IPB forum.
Please Help.
Thank you in advance :D
17 years 9 months ago #647 by johnnydement
Not yet, converters are a must, but right now we're more concerned on getting kunena stable, and j1.5 native.
there's any old FB ipb converter? that "could" do the trick...
17 years 9 months ago #770 by Zoolge
Replied by Zoolge on topic Re:Converting IPB to Kunena
Ok thank you. Do you know where i can find the FB IPB converter? Also then can I convert from FB to Kunena?
Thank You.
17 years 9 months ago #774 by johnnydement
Yes, upgrading from FB to kunena is as easy as uninstall FB1.0.5 install kunena ;)
YOu could also, if you can't find any ipb one, use the ipb to smf, and from smf to FB ;)
converters "could" be in old BOJ forums www.bestofjoomla.com
17 years 9 months ago - 17 years 9 months ago #1339 by Zoolge
Thank you, I managed to convert my ipb to smf however I cant convert my smf to fireboard :(
Do you know of a converter for smf to fireboard that works? I have tried a few and they did not work.
Thank you for your help.
Last edit: 17 years 9 months ago by Zoolge.
17 years 9 months ago #3249 by djXpire
Hi, is there any guides or tool we can use for IPB conversion to Kunena?
Thank you! :laugh:
