Question Lost all images from FB 1.0.0 posts on upgrade to 1.0.8
17 years 2 months ago - 17 years 2 months ago #6078
by CEMag
Lost all images from FB 1.0.0 posts on upgrade to 1.0.8 was created by CEMag
Have just completed a upgrade from 1.0.0 FB to 1.0.8 kunena and we have lost all images attached to the posts.
Is there any thing we should be looking at here? or can do??
The image files are a key part of the content of the site.
Regards,
Regards,
Last edit: 17 years 2 months ago by fxstein.
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
17 years 2 months ago #6090
by grumblemarc
Replied by grumblemarc on topic Re:Lost all images from posts on upgrade to 1.0.8
Read this. Report back if this does/does not help.
docs.kunena.com/index.php/Migration_FAQ
17 years 2 months ago #6097
by CEMag
Replied by CEMag on topic Re:Lost all images from posts on upgrade to 1.0.8
Thanks.
Is this suggested for internal links too?
Im not getting error's - but no images that where added inside the old FB forum show.
All external IMG tagged images work fine.
17 years 2 months ago #6118
by Matias
Replied by Matias on topic Re:Lost all images from posts on upgrade to 1.0.8
Migration FAQ does not help with you on this one. The issue is that the files are located in wrong place.
17 years 2 months ago #6132
by fxstein
Replied by fxstein on topic Re:Lost all images from posts on upgrade to 1.0.8
1.0.0 had a severe bug in terms of location of files within the Joomla tree.
You will have to take the images and move them into the /media/kunena/attachments/legacy/images folder and all files to /media/kunena/attachments/legacy/files.
Check on of the existing posts for the location of the files. Might be best to take them from your backup and copy them to the above folders.
We can provide you with a simple SQL to update all existing posts URLs once you have copied the files into the proper location.
Hope this helps!
fxstein
Hope this helps!
fxstein
Time to create page: 0.227 seconds
