Question links in notification emails still point to fireboard after moving to Kunena ?
17 years 3 months ago #5354 by carsten888
the links in notification emails still point to fireboard after moving to Kunena.
this is particulary annoying cos when you click on them you get to the forum in another order then is set in your preferences.
Joomla 1.0.15
Kunena 1.0.7b
17 years 3 months ago #5368 by Matias
Try to install Kunena 1.0.8, it will fix your links.
17 years 3 months ago #5496 by carsten888
17 years 3 months ago #5498 by carsten888
aAAAaaagh!
after an update the forum configuration is overwritten! of course i got a backup, but if it not the whole point of having the config in the database (unlike fireboard, which had the config in a file) to make it easyer to update?
Kunena got the config in the database and no tables get deleted on uninstall, so you might as well release patches for updates.
17 years 3 months ago #5515 by Matias
Some FB based errors in the configuration table have been fixed. But it SHOULD not overwrite the whole configuration.
Is this what happened? What information was lost?
17 years 3 months ago #5854 by carsten888
all the settings on the configuration-page. I just installed the new version and all the default settings overwrote my own settings.
Time to create page: 0.343 seconds
