Question Avatar Problem (bug: wont show them) Solved!
17 years 9 months ago - 17 years 9 months ago #5295 by quistler
Hi all, i just did a fresh install of the kunena Forums on my website.
it's working great, except the avatar part.
I made 2 screenshots to show u my problem.
it look likes he cant find my files.. but the ARE in the right dir.
the dir = chmod to full acces.
iam verry confused..
Last edit: 17 years 9 months ago by quistler.
17 years 9 months ago #5422 by Harterhund
Hallo,
fbfiles set to 777 (not 644 = image not aviable)
avatars set to 777 (not 644 = image not aviable)
gallery set to 777 (not 644 = image not aviable)
mfg Harterhund
17 years 9 months ago #5483 by moof
I had a similar problem where i had avatars and then they vanished, for no reason I had'nt even logged in the backend. But a quick uninstall and reinstall and rebuild of the menu item returned everything back to normal. May help, may not!
17 years 9 months ago #5716 by quistler
Harterhund:
Hi, I did the chmod on the folders but the avatars still wont show.
Moof:
This is my second install of kunena, first i installed it, with this "bug a.k.a. error" so i switched to agora forum's.. but that sucked even more so i decided to come back and fix this bug instead..
thanks for the help.. but it didnt work :)
grtz from holland :D
17 years 9 months ago #5721 by fxstein
Fortunately this is not a bug. I checked out your site and the servers response when looking at any of the avatars is:
Forbidden
You do not have permission to access this document.
Web Server at bit-force.nl
This is clearly a permissions issue. You can test for yourself with this URL:
bit-force.nl/media/kunena/attachments/le...s/gallery/skater.gif
Hope this helps!
fxstein
17 years 9 months ago - 17 years 9 months ago #5929 by quistler
Thank You!!!! :D
All this folders+files where 777: fbfiles/avatars/gallery/skater.gif
I forgot to CHmod /images to 777!
Sorry Harterhund you where right @ the beginning!!
grtz!
