Question User post gives error
17 years 9 months ago #5655 by alemdag
Replied by alemdag on topic Re:User post gives error
Thank you for the reply. Eventually found the log file (was hidden). This is what it says;
[Sat Feb 21 22:58:18 2009] [error] [client 78.105.90.107] malformed header from script. Bad header=/home/alemdag/dead.letter... S: php-script, referer: www.xxxx.org/index.php?option=com_kunena...y&catid=9&replyto=12
[Sat Feb 21 22:59:35 2009] [error] [client 78.105.90.107] malformed header from script. Bad header=/home/alemdag/dead.letter... S: php-script, referer: www.xxxx.org/index.php?option=com_kunena...ost&do=reply&catid=3
17 years 9 months ago #5685 by Matias
Replied by Matias on topic Re:User post gives error
Can the file be corrupted..? Try to copy the file(s) manually from the zip.
17 years 9 months ago - 17 years 9 months ago #5737 by alemdag
Done that, no change. I think I will give up on this forum. When uninstalled, apparently it doesn't clear the sql files and I have no clue which tables it uses.
Last edit: 17 years 9 months ago by alemdag.
17 years 9 months ago #5738 by Matias
It doesn't clean tables because of uninstalling it is the only way to upgrade to new version (in order to maintain J1.0 compatibility). You can remove tables manually. All of them have jos_fb_ prefix.
