Question How to upgrade: FB1.0.4 to K1.0.8 ?
17 years 3 months ago #4742 by suman
Hi
One of my site is using FB1.0.4 edition. Not the RC editions.
FireBoard 1.0.4 Stable [ Teakwood ] 23 December 2007
  • How to upgrade to K1.0.8 ?
  • Also, how to un-install FB after Kunena starts running ?
  • and How to redirect old FB URLs to new Kunena URL ?
Thanks in advance.
17 years 3 months ago #4743 by whouse
You will need to run the converter for FB 1.0.4 to 1.0.5 to get your config data converted to new db changes. You can search the board here for the converter. Then, you can just uninstall FB, disable any FB module you have currently enabled, then install Kunena 1.0.8.
17 years 3 months ago #4745 by suman
17 years 3 months ago #4747 by whouse
No problem! ;)
If you still need help once you get going on it, let us know. We want to help!
17 years 3 months ago #4781 by suman
Upgrade went smoothly. Thanks for your kind help :)
Few more questions :P -
1. I can't set Board Time Offset to 10.5 !! Its either 10 or 11 :(
2. What are the new names of these module-positions : fb_msg_t, fb_msg_b, fb_msg_1, fb_msg_2, fb_bottom etc.
17 years 3 months ago #4793 by whouse
I believe those are for adds or whatnot so you can publish your adsense module in one of those positions or whatever other banner or add module you may use.
Not sure on the offset. I've never heard of being half an hour offset. I'm sure someone else may be able to help you with that. ;)
Time to create page: 0.240 seconds
