Question Where to get Help ?
- tecselecta
17 years 9 months ago #3549
by tecselecta
Where to get Help ? was created by tecselecta
Browsing around this site I did not find any help. Some Kunena terms and functionalities are still unknown and it is useless to search the site. For instance, How to delete a post, what is the meaning of "Remove Sample Data", etc. Where are such explanations?
Best Regards
Charles Goodwell
Best Regards
Charles Goodwell
17 years 9 months ago #3555
by whouse
Replied by whouse on topic Re:Where to get Help ?
I'm unaware of any current documentation related to that however the Kunena team, while dedicating 95% of it's time to coding, is also working out documentation. I know that this does not answer your questions so I'll try to do that here.
Deleting a post:
This is done on the front end while viewing the post in question. If you are an admin or moderator, you should see the moderation tools buttons at the bottom of the post. Buttons such as merge, split, delete, edit, and move. These are your moderation fucntions. If you scroll to a post you wish to delete, find the delete button directly under the post text and click it. This will delete only the post. If you wish to delete the entire thread, simply delete the beginning post in the thread. That will delete the entire thread.
Remove Sample Data:
This removes the sample data if it was installed. If sample data was never installed, you shouldn't see this option (that is if memory serves me correctly). Sample data is really used for brand new fresh installs and shouldn't be used with a site that already has data in it. What it does is create sample categories, forums, and posts as an example to a new admin on how things are set up.
Hope this helps.
whouse
Deleting a post:
Remove Sample Data:
Hope this helps.
whouse
- johnnydement
- Elite Member
- Thank you received: 5
17 years 9 months ago #3561
by johnnydement
Replied by johnnydement on topic Re:Where to get Help ?
If you need help, please don't hesitate to ask for it, we will be pleased to help you
Our documentation is currently being done, but it requires time to get a good one, so you're welcome to join our efforts in the documentation teams
thanks!
thanks!
- tecselecta
17 years 9 months ago #3564
by tecselecta
Thanks !
It is a pleasure to help you. But I still would like to get info about deleting threads, changing category post, and so on.
Go ahead, Kunena is great.
Replied by tecselecta on topic Re:Where to get Help ?
