Question Upgrade from Fireboard 1.0.4
17 years 9 months ago #3136 by li_gordon
I currently have Fireboard 1.0.4 installed on 1.0.15 on a different server.
I have Kunena installed on Joomla 1.59 installed
I want to take the data from fireboard and upload it over to kunena using phpMyAdmin. Is there a query out there that will do it for me? Or should I just copy the tables from fireboard and import them into my 1.5 database and manually upload the data.
I have been looking around and don't see a script...
thanks,
Laura
17 years 9 months ago #3142 by grumblemarc
Sorry. No script or query that will do that for you. I think you will have to upgrade the old FB forum as outlined here.
www.kunena.com/forum?func=view&catid=19&id=1280nolder than 1.5.
Kunena will not upgrade any version of FB
Only then will the database be compatible with Kunena. Then you can export the Kunena tables from the old install into the new one.
17 years 9 months ago - 17 years 9 months ago #3153 by fxstein
Just to be clear:
Kunena will upgrade from ANY prior FB version as long as it is on the same system, in the same database. The only uptional step is to run the fb_converter utility for FB version 1.0.4 or older. But you can skip that, if you are ok entering the config parameters in the backend by hand.
If you want to switch hosts, I recommend you use phpMyAdmin to export all FB tables (jos_fb_xxxxx) and import them onto your new system (or Joomla 1.5 install) also with phpMyAdmin.
Once all those tables are migrated, you simply install Kunena and it will do all necessary upgrade for you.
It need to happen in that order. You cannot install Kunena and the copy tables - that would break it. If you want to wipe out an existing Kunena test install, simply uninstall it and manually drop all jos_fb_xxxxx tables. The you can do the migration and install Kunena again so it will perform the proper upgrades to the database.
Hope this helps!
fxstein
Last edit: 17 years 9 months ago by fxstein.
17 years 9 months ago #3156 by grumblemarc
Thanks for the clarification. Would hate it if I caused undue work and anguish!
17 years 6 months ago #15210 by shaun.reid
ok I tryed to do this i have joomlaboard 1.1.5 and got this error in phpmyadmin
No data was received to import. Either no file name was submitted, or the file size exceeded the maximum size permitted by your PHP configuration. See FAQ 1.16.
is there another way to upgrade my old joomla 1.0 forum? my new site is on a different database - Finding this to be quite a difficalt process
Time to create page: 0.159 seconds
