Question Upgrade from SVN
17 years 9 months ago #2934
by peamak
Upgrade from SVN was created by peamak
Hi everyone !
This forum extension is truly great so a big thumb up to the developpers !!
I installed Kunena without any problem and I would like to update to the latest SVN. I accessed the files via svnX (tortoise or whatever but for osX) and I'm just wondering how to update now : should I just upload the files by FTP and overwrite everything (for some extension I can do it and for others I can't, it can screw things up badly) ?
And also, I took every folder, even though I know I don't *need* everything. So, do I need to upload the files in root/tags/1.0.7b/ or another one ?
I'm sorry if this is a dummy question... I tried many search in this forum and couldn't manage to find an answer...
Thanks for any hint !
17 years 9 months ago #2936
by fxstein
Replied by fxstein on topic Re:Upgrade from SVN
Sorry - we currently don't have documentation on how to use the SVN available. We are working on a dedicated documentation project, that will include deatils on how to setup a developer environment with access to the SVN. Since we are busy rolling out 1.0.8 we have not had a chance to focus on those auxiliary 'features'.
The file structure and some of the files are NOT a 1:1 copy between the SVN and your install.
Once 1.0.8 is out we will revisit this.
Have a great day!
fxstein
Have a great day!
fxstein
17 years 9 months ago - 17 years 9 months ago #2938
by peamak
Replied by peamak on topic Re:Upgrade from SVN
That's too bad... anyway, I will look in the forum for solutions to my problems.
Keep up the good work
Thanks for this super quick reply !
cheers (and have a great day too)
Last edit: 17 years 9 months ago by peamak.
17 years 9 months ago #2966
by Matias
Replied by Matias on topic Re:Upgrade from SVN
I have this (run in legacy dir):
rm -rf TARGET/components/com_kunena
rm -rf TARGET/administrator/components/com_kunena
cp -r components/com_kunena TARGET/components/
cp -r administrator/components/com_kunena TARGET/administrator/components/
It works for me if I want to check small changes, but does not update database.. So you may mess something up..
