Question Kunena crashed after creating 4th Forum any ideas?
17 years 9 months ago #2905 by arielzriel
The following is the error I get:
Fatal error: Unable to get unread messages count and first id.\nDB function failed with error number 1146
Table 'joomla_dev.jos_fb_messages' doesn't exist SQL=SELECT thread, MIN(id) AS lastread, SUM(1) AS unread FROM jos_fb_messages WHERE thread IN ('2') AND time>'1234533975' GROUP BY thread
SQL =
in /usr/local/apache2/htdocs/joomla_dev/components/com_kunena/lib/kunena.debug.php on line 37
Best regards,
Ariel
17 years 9 months ago #2912 by whouse
It looks like you are using an old version of Kunena. The version displayed is 1.0.6. Version 1.0.7b is available and we're nearly done with v 1.0.8 stable. If this is the case, could you update to 1.0.7b and see if your problem still persists?
17 years 9 months ago #2979 by tiharr
I have the same problem with Kunena version 1.0.7b installed on Joomla 1.0.12. I only have one forum created with one post and I get the error. Based on the error message it appears to be looking for a table that doesn't exist. My Joomla database prefix is "jos010012_" rather than "jos_".
17 years 9 months ago #3095 by Matias
In both of the cases there's something very wrong in the database tables. It looks like there is no josx_fb_messages, so the installation has failed to create them.
I'd advice to uninstall Kunena, remove all jos_fb_ tables by using phpmyadmin (or similar) and to wait for Kunena 1.0.8, which will come early on next week.
BTW: do you have the same problem if you install FB 1.0.5RC2?
