Question Problem after installation
17 years 9 months ago - 17 years 9 months ago #2310 by tyger
I just install Kunena Forum and i have a problem in administration panel to kunena component, in the footer i have an error:
Warning: Could not load latest Version record.\nDB function failed with error number 1146
Table 'db268253879.jos_fb_version' doesn't exist SQL=SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1;
SQL =
SELECT
`version`,
`versiondate`,
`installdate`,
`build`,
`versionname`
in /homepages/26/d224330791/htdocs/joomla/components/com_kunena/lib/kunena.debug.php on line 52
Same problem i have when i install Kunena latest module.
Does anybody how do i fix this?
Sorry for my english.
Last edit: 17 years 9 months ago by tyger.
17 years 9 months ago #2313 by fxstein
Seems like your install failed or was aborted by a php timeout prematurely.
Please set the php timeout to 120 sec (this is a common workaround for many component installs on J1.5 - the installer can be very slow for larger components like Kunena)
Then uninstall Kunena followed by a new install.
Make sure you don't end up on a blank page (php timeout) or with errors.
That should do it.
