Question Captcha problem when board is "open" for visitors
17 years 9 months ago - 17 years 9 months ago #1821 by lammet
Hi.
I first have to congratulate you guys for an amazing app for Joomla.
I believe i have had this when i used FireBoard also but wont be able to find out
hove to fix this again.
When the board is set to public access the captcha would be activated, and
when i do this I'll get this error:
Someone who have an answer?
BR
Lammet
Last edit: 17 years 9 months ago by lammet.
17 years 9 months ago #1997 by dma
Hi!
Is this still a problem for you, if yes do you have a link where I can see this?
17 years 9 months ago - 17 years 9 months ago #1999 by SMurflalus
I can't see images either - only enter code field. I use J!1.5.9. & CB 1.2 stable with CBrecaptcha and Kunena is integrated with CB ( site not published yet). I need Kunena opened for visitors with captcha activated too.
Thx for Kunena. Waitin' for 1.5 native.
Any solution with captcha ?
Thx
D.
Edited few minutes later:
I've found the reason but not solution :-(
My site is multilingual (joomfish), so I've translated kunena.english.php--->kunena.polish.php in Dreamweaver as UTF-8 ( as my all site is). Probably there's a reason of my problem, but I don't know how to solve it...
( german and english site is OK)
Any idea, pls ?
Uff! Solved!
I've found my own mistakes in my tanslation.php . That's all.
Captcha works fine now.
rgds
D.
Last edit: 17 years 9 months ago by SMurflalus.
17 years 9 months ago - 17 years 9 months ago #2099 by lammet
Hi.
Yes still a problem.
I opened the forum for public again and you can use the link below to see it:
www.sportfiskarna.net/index.php?option=c...&catid=2&replyto=246
The strange thing is when i tested this on another site on the same server all looks OK.
I have double checked the settings and the file permissions in com_kunenua and
they all look the same.
BR
Lammet
EDIT: The strange thing is that i installed FireBoard again and Fireboard works... How come?
17 years 9 months ago #2108 by dma
Is this test site also in swedish or did you test it in english?
17 years 9 months ago #2110 by dma
SMurflalus wrote:
Uff! Solved!
/quote]
Great :)
So what was your problem?
