Question Installation wont complete
- naveen_rang
right after the first line, which says '<?php'
Add set_time_limit(300);
so the first and the second line of your index.php should look like the following:
1 <?php
2 set_time_limit(300);
hosting companies have a time out of 30 seconds and whatever you do, they wont change that for you. I faced the same problem. However, after i put this one liner code, everything works like a charm for me.
naveen
RobertNL:
It looks like that some of the tables exists and because of that your installation failed in the last message. Send me PM with your site info and account that have install/uninstall rights. I try to find out why installation fails..
I have pm-ed you the info but i dont see any reaction/action.
The kunena install is in the /tmp folder for you to install.
Can you maybe give a date/time that you will be able to check my problem so i can maybe assist / help you?
Greetings,
Robert
