Question how can i upgrade with out losing language settings ?
17 years 6 months ago #17464 by a7medo778
hello there
i installed Kunena the Arabic edition that i found on joomla forums
it was version 1.0.8
now i wanna upgrade to 1.0.10
how can i do that without losing the language options that were added to the arabic version ??
in an other unrelated thing
what can i do currently to get max integration with jomsocial ?
i checked the specific forum but couldn't get a clear idea
btw : great job on the forum and keep up the development
thanks in advanced
ahmed
17 years 6 months ago #17471 by grumblemarc
Maybe that's a question you should pose to the people you got the Arabic version from. No one knows what was modified in that version so I would not hazard a guess whether or not ou can upgrade it with 1.0.10.
As for your other thing. What does max integration mean?
17 years 6 months ago #17491 by a7medo778
for the arabic version its like all other languages versions i guess ( translated versions )
the other thing : max = every thing i can do to make more integrated ( shared profiles maybe and that sort of stuff )
17 years 5 months ago #17874 by TrueFact
Arabic is just the same of the original English file. I'm working on translating 1.0.10 file now.
I'll be adding it within two days maximum.
17 years 5 months ago #17877 by a7medo778
thanks alot trueFact
if you needed any help what so ever i will be more than glad to help
17 years 5 months ago - 17 years 5 months ago #17878 by TrueFact
A friend hinted me of a difftool that can be run on Windows platform. using it, I've saved myself a day of work I guess.
here's the Arabic file for K1.0.10
copy the file to the following path into your site:
administrator\components\com_kunena\language
File Attachment:
File Name: kunena-11f...17a7.zip
File Size:31.74 KB
Last edit: 17 years 5 months ago by TrueFact. Reason: Re-Attaching the file
