Question Images not loading in IE, just a red X...
17 years 3 months ago #1699
by mleroy
Images not loading in IE, just a red X... was created by mleroy
Hey there,
Images (whatever they are) are not loading in IE...just a red X (failed load) nothing appears in firefox....
Not sure how to fix it.
stevengotstoned.com/joomla/index.php?opt...com_kunena&Itemid=30
Thanks for your help!!
Mark.
Mark.
17 years 3 months ago #1711
by fxstein
Replied by fxstein on topic Re:Images not loading in IE, just a red X...
This is a known limitation of the default_grey template: It does not come with a separate set of images. Because of that you cannot select default_grey as image source. If you are running defualt_ex, you will need to select default_ex as image source as well.
Hope this helps!
fxstein
Hope this helps!
fxstein
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
17 years 3 months ago #1784
by grumblemarc
Replied by grumblemarc on topic Re:Images not loading in IE, just a red X...
This was always a peeve of mine on FB. Is there any way to have incorporate a check so that if there is no image set it does not give the option to pick one and goes to the default?
17 years 3 months ago #1813
by mleroy
Replied by mleroy on topic Re:Images not loading in IE, just a red X...
Thanks so much, Fxstein...that did the trick!
Have another question...
Is there a way to have easier navigation to avatar? You have to click on my profile, then the smaller my profile afterwards...
Make that two questions!...Is there also a way to combine logins with the login module on my home page, with Kunena and then with jomcomment?
Thanks again!
Mark.
Thanks again!
Mark.
17 years 2 months ago #4780
by wizz001
Replied by wizz001 on topic Re:Images not loading in IE, just a red X...
17 years 2 months ago #4800
by Matias
Replied by Matias on topic Re:Images not loading in IE, just a red X...
wizz001: Your image seems to be corrupted. Try look at it:
URL REMOVED /components/com_kunena/template/default_ex/images/english/icons/tlatest.gif
Time to create page: 0.337 seconds
