- Thank you received: 565
Question Can't Save Configuration - Not solved
Backup table is made every time you safe configuration. It first moves old configuration to backup table and then removes the first table. After that it adds a new table and fills all configuration options into it. Don't ask me, why it works like that -- I don't know.
Debug just logs every query -- it has no effect on how MySQL gets queried.
It's interesting that saving configuration works with debug on, but not off. They should have no difference.
Please tell me your Kunena, Joomla, PHP and MySQL versions. Have you also tried to install Kunena into another server (local vs. public)?
1. Kunena 1.1.09, I downgraded from Kunena 1.1.10, The problem is the same with both versions. But 09 is better than 10 for me because templates work with 09
2. Joomla 1.5.10 - Latest
3. Apache ver. 2.2.10 (Unix)
PHP version 5.2.* server29.000webhost.com/phpinfo.php
MySQL ver. 5.0.51-community
4. Nope I haven't tried it on local. For that I have to install apache, php, mysql, right? :huh:
Well matias, what can I do next?
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
* While I'm at it, do u perhaps know how to show avatar and profile view in a module, you see i just copied over view profile link from kunena and added a external link to the menu and added the "view profile link" in the link bar. So that take care of viewing profile, but how may i say can i show each members avatar, i thin community builder has a module like that.. or do i have to start a new thread for this?
Can't Save Configuration - Not solved, is solved, right?
For this question open a new thread.* While I'm at it, do u perhaps know how to show avatar and profile view in a module, you see i just copied over view profile link from kunena and added a external link to the menu and added the "view profile link" in the link bar. So that take care of viewing profile, but how may i say can i show each members avatar, i thin community builder has a module like that.. or do i have to start a new thread for this?
Regards
