Question will there be an upgrade path to 1.5native from 1.0.9
17 years 6 months ago #15896 by sanjeewasam
I am about to installed 1.0.9 stable in live site (have tested it in local and love it).
I am little concerned whether I would be stuck with this version once 1.5 stable. Could the development team please clarify whether you plan to release simple migration path to 1.5 stable (once release) without loosing any forum items in 1.x.
Many thanks.
sanjeewa
17 years 6 months ago #15897 by fxstein
Absolutely! All Kunena versions can be upgraded on the same system with a simple uninstall/re-install. Only the Joomla upgrade from J 1.0.x to J 1.5.x is a little more involving. If you are already on J 1.5.x all you need to do is uninstall Kunena 1.0.9 and install Kunena 1.5.x and you will be set. At that point you will also be able to disable the Legacy plugin unless other components require it.
The upgrade from Kunena 1.0.9 to Kunena 1.5.x does not require any manual steps or sql updates. Everything is fully automatic.
Hope this helps!
fxstein
