Question Best way for moving site?
17 years 6 months ago #15795 by MrNick
We have an old site, Joomla 1.0.15 - CB 1.2 - Fireboard 1.0.5RC1
Now we are woving to a new host and at the same time upgrade.
I have installed Joomla 1.5.10 - CB 1.2 - Fireboard 1.0.5RC2
Now i just have learned that Kunena have "take over" so i wonder how do i go the right way?
Should i upgrade to Kunena on my old site first and then move it to my new site?
Or should i move my old database for Fireboard to my new site and then upgrade?
I have also had problems to learn how to move the forum to a new server, havent find any "backup function" in Fireboard so if someone please could point me into a direktion to solve this the best way i would be greatfull.
Excuse for bat written english, hope you anderstand my problems.
17 years 6 months ago #15810 by Lintzy
Replied by Lintzy on topic Re:Best way for moving site?
You should first move your old database from Fireboard to the new site and then upgrade.
The folders of Fireboard are:
/components/com_fireboard
/administrator/components/com_fireboard
/media/kunena/attachments/legacy
backup these three folders per FTP. A Backup of your Database make with the export - function in PHP-MyAdmin. If you only want to backup the Database Tables of Fireboard export only the tables with prefix jos_fb_
And look into the Kunena Docoumentation. There are a lot of articles about Installation , Migration and Technical Requirements, Readmes and more.
17 years 6 months ago #15921 by MrNick
Replied by MrNick on topic Re:Best way for moving site?
Hi and thanks for the support Lintzy.
I have moved over the folders so now im going to export the tables for FB ( jos_fb ).
Now im new to phpMyAdmin and have a few more q.
When i click om "Export" there is a few alternatives to chose on how i want to export the table. Is there any special choises i should make or is the default settings ok and i just go for the "GO" button?
17 years 6 months ago #15928 by MrNick
Ok, i tried and it seems it worked out well so far, so i try another Q instead :)
Now, how should i in the best way move over my CB 1.2 to the new site.
Is it possible just to do the same thing as for FB?
