Question installation fails
When I click on components I see the forum, I click on it and see alot of errors and this at the bottom:
edit: I should add that I have uninstalled and reinstalled several times, including uploading the zip to the /tmp folder. I went into pypmyadmin and had a look for 'xxx.jos_fb_*' but there is nothing there.
300 seconds should be enough to work a 1.09 Meg file.
It starts moving quickly, there is a pretty active php process, then gets to about 1/3 through it then sits there until the timeout. After the error page I can see part of the component is there, just not completed. It's getting stuck on something.
I'm also using most recent kunena stable and most recent joomla.
I've tried uploading the zip from the desktop using the joomla installer, uploading the zip to a tmp folder, extracting the zip, and I've tried installing from a url.
I'm still having the same problem for a few days now. Anything else I could try?
Also check you web-server error log if there is anything indicating an issue.
