Question cannot read posts after migration FB 1.05 > Ku 1.09
17 years 6 months ago #15214 by jastray
I have migrated from Fireboard 1.05 to Kunena 1.09 and everything is working fine except the most relevant feature: I cannot read posts.
It seams to be a Template issue, but I have not been able to solve the trouble.
My environment:
PHP funcionando con: Linux host25.digitalvalley.com 2.6.18-128.1.6.el5 #1 SMP Wed Apr 1 09:10:25 EDT 2009 x86_64
Data base ver: 5.0.45
Cotejamiento(collation): utf8_general_ci
Versión de PHP: 5.1.6
Servidor web: Apache/2.2.3 (CentOS)
Interfaz PHP del servidor: apache2handler
Versión de Joomla!: Joomla! 1.5.9 Production/Stable [ Vatani ] 9-January-2009 23:00 GMT
Components:
Community Builder 1.2
PollXT
Remository
Enclosed I'm sending two screen copies: I have also changed the general template (Rockettheme Chromatophore) to the standard "RHUK Milkyway" but still the same problem.
I have previously tested on my server (wamp environment) and everything works fine. When I tried the upgrade on my hosted environment, I got an OK installation message acompained by this message: www.cina.es/img/errores_de_instalacion.JPG
I did what it said: I installed the kunena.files.distribution directories & files under the images/folder but still have the same trouble.
I have even made a FTP "directory/file compare" between my test environment and production environment and both "../administrator/components/com_kunena" and "../components/com_kunena" have the same contents.
What else can I do?
Curiosily enough, I have also installed "ObjectClarity Kunena Discussbot" and then I can perfectly read all posts discusing content articles:
www.cina.es/img/posts_commenting_articles.JPG
17 years 6 months ago - 17 years 6 months ago #15215 by sozzled
G'day, jastray :)
There are a couple of well-known "gotchas" (i.e. traps for young players).
  1. Certain Rockettheme components (notoriously, the "RokCandy" plugin) are known to conflict with Kunena. If you're using them, disable them.
  2. Whether or not you're likely to use the announcements feature, with Kunena 1.0.9 you must enable the feature (see docs.kunena.com/index.php/Configuration_Tips ).
Last edit: 17 years 6 months ago by sozzled.
17 years 6 months ago #15242 by jastray
Yes, I'm running a rockettheme template buy still not using any Rockettheme components beside the template itself.
And yes, I have followd all the "configuration tips" docs.kunena.com/index.php/Configuration , including the announcements feature.
The question that intrigues me is that my WAMP environment works perfectly, but in the hosted environment it does nor.
Any way, thank you very much for your time.
17 years 6 months ago #15276 by sozzled
The only other thing that I can tell, from the screenshots you provided, is that you are using a language-customised Kunena template. Have you attempted to use the Kunena default_ex template which is also recommended as a setting in the Configuration tips that I posted before)? It's not just a case of "enabling announcements", it's everything. B)
If your WAMP test site works, have you meticulously checked your hosted site to ensure that your Kunena configuration settings are identical? And what other differences exist between your WAMP test site and the hosted site? :)
17 years 6 months ago #15431 by Matias
@ jastray: See PM. Did it work for you?
17 years 6 months ago #15459 by jastray
I've just read your message. I'll test it and let you know, thank you very much.
