Question Please Help!! Can't use avatars after long build. **SOLVED**
17 years 6 months ago - 17 years 6 months ago #15032 by moof
Hi I've just spent hours intergrating kunena 1.0.9 into my site here mylittleocean.co.uk/Forum.html with sef urls and everything ready to go, but for some reason I can't select avatars and I can't upload them either infact nothing works where avatars are concerned :angry:
I have everything set to yes for avatars in the backend please help I'm stuck and have spent about 3hrs getting it intergrated into the theme ;) :angry:
Last edit: 17 years 6 months ago by moof.
17 years 6 months ago - 17 years 6 months ago #15046 by sozzled
moof wrote:
... for some reason I can't select avatars and I can't upload them either infact nothing works where avatars are concerned :angry:
G'day, moof. I hate to sound like a killjoy, mate, but your avatar display is working (after a fashion) although I sympathise with your frustration in not being able to upload your own avatar.
95% of these frustrating problems occur as the result of users changing the initial Kunena settings - it's an easy thing to do when there are 134 of them - but it's relatively straightforward to back-track and figure out how each of them work.
In any troubleshooting, keep things simple. Out-of-the-box, Kunena works without changing any setting. Sure, the forum may not blend well into your website's theme, but that's merely matter of cosmetics. So, for starters, choose an image for your avatar that's simple and not large (say, 50 Kb). The fact that you could upload an avatar here at www.kunena.com indicates that the avatar upload facility works, doesn't it?
Secondly, change your Kunena settings back to their original "factory" values: see docs.kunena.com/index.php/Kunena_Configuration and slowly and methodically make your way through adjusting things to suit your needs.
Lastly, it's possible that some other Joomla component may be interfering with the operation. It's possible, for example, that you have a peculiar security protection setting on your avatar upload folder. It may also be possible that you do not have the GD2 image processor installed.
They're just a few thoughts to start you on your way. Good luck and stay cool. B)
Last edit: 17 years 6 months ago by sozzled.
17 years 6 months ago - 17 years 6 months ago #15048 by johnnydement
good integration ;)
nothing we can't do without a test user, and some more info ;)
Last edit: 17 years 6 months ago by johnnydement.
17 years 6 months ago #15053 by moof
the problem was this mod www.kunena.com/forum?func=view&catid=13&id=13799 once remove everything is fine, shame cause it wrote the urls nice :angry:
17 years 6 months ago #15054 by grumblemarc
sh404sef seems to cause more problems than it solves. Problems reported all over the Joomla community being reported because of it.
17 years 6 months ago - 17 years 6 months ago #15055 by moof
Ive never bothered with sh404sef untill now. I thought everyone else used it so i'd give it a tryout Is there any real advantage to having it considering the headaches?
