Question Migration to another server, problem
17 years 6 months ago #14955 by vlado85
Hello. I moved the site to another server and now I have a problem with Kukena encoding. Serbian Latin characters ŠĐČĆŽ are turned in -?-
Joomla and all posts in Kunena are fine, only Kunena (administration) and Community builder encoding does not work properly.
I opened phpMyAdmin and I see that it is all set to utf8-global-ci. I use a script that automatically moves the table, but nothing has happened.
Do you have an idea?
This is link:
www.palelive.com/servisi/forum.html
17 years 6 months ago #15050 by Matias
Did you have right encoding in your SQL dump file? Sometimes tables are ok, but the contents in sql dump file is different (UTF8 <--> Latin1)..
