Question Upgrading from Fireboard to Kunena 1.0.9
I just built my site and integrated Fireboard, i assume its the latest fireboard version 1.0.5RC2, and the link to that is here: www.phillyrant.com/index.php?option=com_kunena&Itemid=53 . I just came across this as i didnt know that Fireboard was all but dead and being replaced. I have the link to install Kunena 1.0.9 here: docs.kunena.com/index.php/Installation_Instructions but i dont notice if this is a way to upgrade my current forum or not? I am using the 1.5.10 RHUK Milkyway template. I also have to point out that i am running in Legacy Mode 1.0. So my questions are:
1. Do i have to delete my current fireboard and upload the new Kunena board?
2. Are there any bad bugs in the new Kunena that maybe i should hold off on and wait for them to be fixed?
3. Is this new Kunena as easy to install & integrate into my site as the fireboard?
you can read this : docs.kunena.com/index.php/How_to_Install_or_Upgrade_Kunena
1°) You must uninstall fireboard and install kunena
2°) kunena 1.0.9 is a stable version, but there are few bugs or if haved seen bugs you can wait for Kunena 1.0.10
3°) This is the same thing that fireboard
So the Kunena 1.0.9 works in "Legacy" mode & is compatible with Joomla 1.5.x?
Also in uninstalling fireboard then do i lose all my forums & members? Will i have to start over again.
