Important Avatar not displaying
I'm using v 1.0.8
The avatar system appears to be working. That is when I upload an image Kunena reports that the avatar was uploaded successfully. However, the avatar does not display. When In IE the image place holder is there and when I check the properties of the missing image the path shows as /media/kunena/attachments/legacy/avatars/62.jpg. BUT there is no such directory /fbffiles in my installation!!
I'm confused as Kunena does not report any errors when uploading or deleting avatars. Furthermore there are no images displayed for the default avatar gallery. :S
Any help greatly appreciated.
Thanks,
Simon
Did you follow the instructions during installation?
1) Copy components/com_kunena/kunena.files.distribution/ into images/fbfiles
2) Change permissions for images/fbfiles and all its subdirectories so that your web server has write access to them all.
I hope that this helped you!
If for any reason the avatar upload/delete/etc doesn't work, Kunena does not throw an error but reports a successful action. I guess this is a bug?
Now that we have fixed most of the worst legacy issues in Kunena, we are preparing to rewrite everything piece by piece to Joomla! 1.5 MVC model.
