Question Fatal error after installation - WAMP
17 years 9 months ago - 17 years 9 months ago #1305 by jezp
Hi.
I get the notice that the install was successful, then when I go to the Kunena control and there are several tables with information, and the message:
Fatal error: Unable to load messages.\nDB function failed with error number 1146
Table 'joomla_kitty.jos_fb_messages' doesn't exist SQL=SELECT * FROM jos_fb_messages WHERE parent = 0 AND hits > 0 ORDER BY hits DESC LIMIT 5
SQL =
in C:\wamp\www\joomla1\components\com_kunena\lib\kunena.debug.php on line 37
(Using WAMP on XP for development)
Any help would be greatly appreciated.
Last edit: 17 years 9 months ago by grumblemarc. Reason: Clarify title.
17 years 9 months ago #1309 by whouse
Do you know what version of php and mysql that WAMP is using?
17 years 9 months ago - 17 years 9 months ago #1317 by jezp
PHP is 5.2.6 and MySQL is 5.0.51b
I don't know if it has any relevance but I had to install/uninstall Kunena prior to this install due to timeout errors (I had to increase the max_execution_time in php.ini).
Last edit: 17 years 9 months ago by jezp. Reason: clarity
17 years 9 months ago #1323 by fxstein
It sounds like the install might have timed out in the middle of creating the tables. If you have access to phpamdmin, you should drop all jos_fb_xxxxx tables and do a fresh install. The can only happen on a brand new install.
Unfortunately the installer is rather slow for a file of 1MB and will not finish in 30 sec on many platforms.
Make sure you have the timeout set to at least 60-120 sec.
Hope this helps!
fxstein
17 years 9 months ago #1325 by jezp
That fixed it - it's up and running now, thank you very much fxstein :)
I did get one install error though - "Creating version table" - is that anything to be worried about?
17 years 9 months ago #1358 by morgo
I have just had something similar, but it is not timeout.
When clicking on the Recent Discussions tab, I get a page without formatting, no joomla content, only Kunena. Looking at the source, it is not a complete page with header, css etc., only Kunena html in it. And at the end this same SQL error message.
What is interesting: my tablename prefix is not 'jos' but 'fm', still in the error message it says it is not able to find this xxx.jos_xxx table. :)
regards, Morgo
