Question Fatal error after installation - WAMP
I get the notice that the install was successful, then when I go to the Kunena control and there are several tables with information, and the message:
Fatal error: Unable to load messages.\nDB function failed with error number 1146
Table 'joomla_kitty.jos_fb_messages' doesn't exist SQL=SELECT * FROM jos_fb_messages WHERE parent = 0 AND hits > 0 ORDER BY hits DESC LIMIT 5
SQL =
in C:\wamp\www\joomla1\components\com_kunena\lib\kunena.debug.php on line 37
(Using WAMP on XP for development)
Any help would be greatly appreciated.
I don't know if it has any relevance but I had to install/uninstall Kunena prior to this install due to timeout errors (I had to increase the max_execution_time in php.ini).
Unfortunately the installer is rather slow for a file of 1MB and will not finish in 30 sec on many platforms.
Make sure you have the timeout set to at least 60-120 sec.
Hope this helps!
fxstein
I did get one install error though - "Creating version table" - is that anything to be worried about?
I have just had something similar, but it is not timeout.
When clicking on the Recent Discussions tab, I get a page without formatting, no joomla content, only Kunena. Looking at the source, it is not a complete page with header, css etc., only Kunena html in it. And at the end this same SQL error message.
What is interesting: my tablename prefix is not 'jos' but 'fm', still in the error message it says it is not able to find this xxx.jos_xxx table.
regards, Morgo
