Question Users missing since upgrade to 1.0.9
I got everything working in 1.0.8 fine.
I just upgraded to 1.0.8 and, although my users appear to show up in the Kunena backend User Configuration, they do not appear in the Joomla User Manager at all.
I have tried pressing Synchronise Users in the Kunena backend and i have tried re-importing the users from my database backup. I also tried re-importing the users and then synchronising from Kunena but only the Super Admin (i.e. me) shows up in Joomla's User Manager.
What on earth is going on? :huh:
I've checked and double checked. I've even browsed the tables for jos_users in both databases and they appear to be the same. Still nothing but the SuperAdmin showing up on the remote server. I may have to revert to 1.0.8
Well, it's gone six AM here and I've been at it all night (again!) So I'm going to sleep on it and have another look later today - hopefully someone can shed some light on it in the meantime.
- johnnydement
- Elite Member
- Thank you received: 5
The behaviour you describe is extremely strange, kunena doesn't modify joomla userbase, in fact sync is one way onlye, to get deleted/newly added users in kunena.
If they appear in your kunena after sync, they should be in jooma...
If you check your mySQL table directly, are they there?
That's brilliant! Yeah, if Maffu logs out of his administrator backend and logs in again, everything should be "normal" (ie, there won't be any filtering). Sounds like the problem has to do with staying "logged-in" to the admin site for a long time. I hope to see a resolution tomorrow.May seem stupid, but you sure not filtering superadministrators?
- johnnydement
- Elite Member
