Important Migration from 1.0.8 to 1.0.9 not working properly....
17 years 5 months ago #12188
by jolmeda
Migration from 1.0.8 to 1.0.9 not working properly.... was created by jolmeda
Hi guys,
I tried to migrate from the 1.0.8 Kunena version to the latest and to start the 1.5 didn't work at all and the 1.0.9 looks like it didn't worked.
I tried to upgrade because of this error we are getting on Internet Explorer.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; InfoPath.2; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Tue, 14 Apr 2009 02:13:52 UTC
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
Line: 0
Char: 0
Code: 0
URI: www.viveurbano.com/expresate.html
Please help team,
Thanks for your great Component.
Peace
Line: 0
Char: 0
Code: 0
Please help team,
Peace
17 years 5 months ago - 17 years 5 months ago #12190
Replied by sozzled on topic Re:Migration from 1.0.8 to 1.0.9 not working properly....
Are we discussing the upgrade from K 1.0.8 to K 1.0.9 on a live production site? In which case, why did you attempt to use K 1.5.0a against every recommendation here not to do so? :ohmy: There have been many discussions here concerning the problems that people have encountered because they attempted to use K 1.5.0a. I suggest you browse through the past week's discussions and I think you'll find the answers you're looking for.
At the very least, you'll know what information you may need to provide so that someone might be able to help you with your specific problem.
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #12191
by jolmeda
Replied by jolmeda on topic Re:Migration from 1.0.8 to 1.0.9 not working properly....
Thanks for your quick reply... Thanks a lot!
I'll check into the forum...
Just to let you know that the downloads you have available are not working properly.
Thanks anyways.
Thanks anyways.
17 years 5 months ago #13137
by Matias
Replied by Matias on topic Re:Migration from 1.0.8 to 1.0.9 not working properly....
This looks like html issue in the template (either Joomla or Kunena).
Can you chack the page with validator.w3.org ?
Time to create page: 0.277 seconds
