Question Downgrade
17 years 7 months ago #10981 by Turbo123
Downgrade was created by Turbo123
Is there anyway to downgrade to an old version? Some issues happened during the installation of the new 1.5 version. I was wondering if there is ANYWAY to downgrade in a safe and timely manner?
Thanks!
17 years 7 months ago - 17 years 7 months ago #10982 by sozzled
Replied by sozzled on topic Re:Downgrade
*** ATTENTION ATTENTION ATTENTION ***
I don't know what part of the original announcement about Kunena 1.5.0a that people didn't read, but let's repeat it again:
As we have written elsewhere, and we will probably continue to write for some time to come, you are strongly advised to install Kunena 1.0.9. Kunena 1.5.0a should only be used by experienced users of earlier versions of Kunena and it should only be installed for testing purposes. In other words, if you instal Kunena 1.5.0a you are doing so at your own risk!
I don't know if there's a "downgrade" procedure. I don't know if it's possible to undo what you've already done.
Can I also add, unless you have evidence that a feature that worked in Kunena 1.0.8 or 1.0.9, does not now work with version 1.5.0a, it's unlikely you'll obtain help with how to use this latest, test version.
I'm sorry I can't be more considerate towards people who are experiencing problems with Kunena 1.5.0a but you were warned. (And, in case anyone is wondering: no, I haven't installed Kunena 1.5.0a and I haven't any intention of installing it at this present time while it's in alpha testing.)
Last edit: 17 years 7 months ago by sozzled.
17 years 7 months ago #10983 by Turbo123
Replied by Turbo123 on topic Re:Downgrade
Ok well thanks for the info... I am a noob for note on that and cannot read things in BOLD BLACK and red.. :)
Do you know of ANYWAY to go from 1.5 to 1.0.9? lol
17 years 7 months ago #10985 by grumblemarc
Replied by grumblemarc on topic Re:Downgrade
If this is not a new install I truly hope you have a backup of your forum before you applied the alpha to it. There is no such thing as a downgrade.
If it is a new install you will have to uninstall and remove all Kunena tables from the database and then install 1.0.9.
17 years 7 months ago #10986 by Turbo123
Ok thanks... I am a noob and have paid for it lol.
17 years 7 months ago #10989 by grumblemarc
I'm guessing that's a NO on the backup?
