- Thank you received: 1
Question Upgrade procedure
First I read the upgrade procedure at
docs.kunena.com/index.php/Upgrade_Instructions
Can it be that step 6 to 8 are not necessary or must I really backup, uninstall, install twice?2. Make a copy of your live site.
3. Uninstall the previous Kunena Forum
4. Install the new Kunena Forum version
5. Test it thoroughly.
6. Backup your live site.
7. Uninstall the previous Kunena Forum on your live site.
8. Install the new Kunena Forum version on your live site.
9. Make any other changes required
10. Check your live site to make sure it is working correctly.
Visit the Kunena documantation .
- johnnydement
- Elite Member
- Thank you received: 5
First 1-5 steps refer to your test install, 6 to 10 refer to live one
3. Uninstall the previous Kunena Forum in the copy of your live site.
4. Install the new Kunena Forum version in the copy of your live site.
Yes, this make sense. Thank you.
BTW: I wrote this above with "Quick Reply". When I hovered about the "Submit"-Button, the yellow tooltip shows texts from another website (the most recent used tab in firefox).
