Question Couple Installation Questions.
17 years 8 months ago #10101 by yamemaru
I'm looking to install this forum, but I have a couple questions before I do.
Currently I use the template JA SANADINE which originally came with the older version (fireboard)
I've never really opened the forums and it has no posts in it. Which brings me to my question,
1) is it better to UPGRADE that fireboard or just uninstall it and install Kunena forums?
2) Does this forum automatically integrate into the body of my layout?
thanks.
17 years 8 months ago #10103 by core2
1): Sice you have no data in your Fireboard install, it doesn't matter what you do. Unistall firbeoard and install kunena. Remember to change your menu item. But before you install have a look at the docs.kunena.com/index.php/Technical_Requirements and the docs.kunena.com/index.php/Installation_Instructions .
2): Kunena doesn't integrate into your Joomla template, but uses it own template system.
PS The next version of Kunena - 1.0.9 - is just around the corner.
Visit the Kunena documantation .
17 years 8 months ago - 17 years 8 months ago #10111 by grumblemarc
To clarify. Ja Sandine NEVER included with the official version of Fireboard. In other words it was never available as a download from Best of Joomla-ever.
Last edit: 17 years 8 months ago by grumblemarc.
17 years 7 months ago #10149 by yamemaru
How much longer do you think it is until the new version?
17 years 7 months ago #10150 by grumblemarc
Have no idea. It's being worked on now.
17 years 7 months ago #10151 by yamemaru
I might just get the current version and upgrade to that then.
