Question Couple Installation Questions.
Currently I use the template JA SANADINE which originally came with the older version (fireboard)
I've never really opened the forums and it has no posts in it. Which brings me to my question,
1) is it better to UPGRADE that fireboard or just uninstall it and install Kunena forums?
2) Does this forum automatically integrate into the body of my layout?
thanks.
2): Kunena doesn't integrate into your Joomla template, but uses it own template system.
PS The next version of Kunena - 1.0.9 - is just around the corner.
Visit the Kunena documantation .
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
1): Sice you have no data in your Fireboard install, it doesn't matter what you do. Unistall firbeoard and install kunena. Remember to change your menu item. But before you install have a look at the docs.kunena.com/index.php/Technical_Requirements and the docs.kunena.com/index.php/Installation_Instructions .
How much longer do you think it is until the new version?
- grumblemarc
- Elite Member
Have no idea. It's being worked on now.
I might just get the current version and upgrade to that then.
