Please Read This First:
This category is only for discussing add-on software products for K 3.0 that were obtained on the download page . Topics about other products obtained from other sources will be deleted.
Other add-ons that were developed by the Kunena team - but no longer maintained - are available on an "as is" basis. People who use these products do so at their own risk.
This category is for the community to share their experiences and to develop their own solutions to problems that they may encounter. Please note that the adminstrators and team moderators are not obligated to reply to topics in this category.
Solved Translation problem with login module
12 years 7 months ago #155622 by 810
On the top is not the login module. Its just the basic kunena. Please install Kunena Language Package.
joomlacode.org/gf/download/frsrelease/19...3.0.5_2014-03-09.zip
12 years 7 months ago #155624 by polleke
i am sorry,
i do not understand what you mean.
You may explain in dutch. As i think you are :-)
regard Jan
12 years 7 months ago #155625 by 810
English: on the top off kunena, you see the login. but thats not the login module.
Dutch: Bovenaan kunena zie je de login, maar dat is niet de login module. Je mist bepaalde vertalingen. Dus je moet de Kunena Language Package installeren. Als het goed is, is het opgelost.
Maar ik denk van niet, omdat je vorige keer ook al problemen had, dat betekend dat de map rechten niet goed staan.
Om de map problemen optelossen moet je Admintools installeren, en dan op fix permissions klikken. Die programma zet alle instellingen weer goed van je mappen.
Installeer daarna weer de Kunena Language Package en kijk of het werkt, Als dat ook niet werkt, moet je de vertaling handmatig in de language map plaatsen.
The following user(s) said Thank You: polleke
12 years 7 months ago - 12 years 7 months ago #155626 by polleke
Hi B10,
i did the languageupdate by hand. and it worked fine.
Now it is all dutch.
thanks
Jan
Last edit: 12 years 7 months ago by polleke.
12 years 7 months ago - 12 years 7 months ago #155628 by Mortti
Hi polleke and 810, I just read whole topic and if I understand right polleke did was not installed latest pkg_kunena_languages_v3.0.5_2014-03-09.zip package and that why he/she use old language files of Kunena?
Anyway, nice to hear that everything works now.
Please give for us also your configuration report, that we can see that your module is up to date.
Last edit: 12 years 7 months ago by Mortti.
12 years 7 months ago - 12 years 7 months ago #155629 by polleke
Well... almost
I did an upgrade from 3.0.2 to 3.0.5
And also an install of the language file using Joomla installer.
There some new files are not overwriten as should be.
So i did an language install using FTP (filezilla) And gave permission to overwrite.
After that it worked fine.
regards Jan
htaccess: Exists | PHP environment: Max execution time: 520 seconds | Max execution memory: 512m | Max file upload: 5M
Joomla default template details : jb06 | author: Jan Broos | version: 1.0 | creationdate: Unknown
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Login 3.0.1
Time to create page: 0.150 seconds
