This category is for the module developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 3.0 and later versions.
Solved Adjust output of module with overrides possible?
12 years 1 month ago #159283 by onki
I am using Kunena and the latest module on my website (onki.de).
The latest module needs 3 line per posting which is too much.
Can I modify the output in that way that there is no new line between the user name and the date just a comma or semicolon?
So it looks like this
Latest posts:
Thread Title
Last post from Username, 2 Hours ago
Shure I can do this in the code but is there a way to do it using an override to avoid doing it again after an update?
Best regards
Onki
12 years 1 month ago #159292 by rich
It would be also a option without semicolon? Then you can try it via css at the end of your Joomla! template.css.
.klatest-itemdetails li.klatest-author { float: left; padding-right: 3px; }
The following user(s) said Thank You: onki
