This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 3.0 and later versions.
Question Kunena Discuss 3.0 Plugin does not allow guests to be the first to post article comments.
10 years 10 months ago #169838 by ruud
Just tested and I do not have this issue?
not logged in (so guest), place comment, topic for article is created and comment is posted as reaction.
probably it works for me because I do not use Joomla caching? (I do use Kunena caching)
sharing = caring
10 years 10 months ago - 10 years 10 months ago #169842 by sozzled
ruud wrote: Just tested and I do not have this issue ... [probably] works for me because I do not use Joomla caching? (I do use Kunena caching)
I must admit that I have not followed the progress of this topic for the two years that it has been running. I posted a topic about Joomla caching, guest posting and Kunena Discuss a couple of months ago and, like this topic, it was not addressed by the developers.
You may have hit upon the reason why Kunena Discuss does not allow guests to be the first to post comments. In actual fact, if you have Joomla caching turned on, guests may not be able to post comments at all. I'm not sure about this and the developers do not seem to know the answer either.
EDIT: Message #2 (which appeared 2 years ago) explains the reason and proposed a way to resolve the problem. Matias (the original developer of Kunena Discuss who is no longer actively involved in the project) wrote that he would "look into it".
The cause of the problem and the short answer to the question is, if you want guests to use Kunena Discuss to post comments about articles, you need to disable Joomla caching on your website.
Last edit: 10 years 10 months ago by sozzled.
10 years 10 months ago #169843 by 810
I merged the fix on Jul 5, so it should work now. Will look at it again.
10 years 10 months ago #169861 by Janurmas
Hi guys, I am a very new with Kunena. I have installed the Kunena discuss plugin on my Joomla 3.4. But, I still confused how to enable the comment. I have published the plugin, but it won't appear o my posts. Please any advice for this issue.
Time to create page: 0.278 seconds
