Solved KunenaDiscuss messing up article id (from JInput) | Fix included
9 years 9 months ago - 9 years 9 months ago #183728 by ruud
Hi, I have a module that will display the latest articles from the same category as the displayed article.
All fine except when there is a post avaialble on Kunena that is displayed via KunenaDiscuss.
here is what happens:
when I var_dump JFactory::getApplication(); I get the followinf JInput information:
object(JInput)#11 (4) { ["options":protected]=> array(0) { } ["filter":protected]=> object(JFilterInput)#12 (8) { ["stripUSC"]=> int(0) ["tagsArray"]=> array(0) { } ["attrArray"]=> array(0) { } ["tagsMethod"]=> int(0) ["attrMethod"]=> int(0) ["xssAuto"]=> int(1) ... ["data":protected]=> &array(5) { ["Itemid"]=> string(4) "1811" ["option"]=> string(11) "com_content" ["view"]=> string(7) "article" ["catid"]=> int(87) ["id"]=> int(1020) } ...
As you can see the article id is 1020... but that real article id is 522???
1020 is the Kunena thread_id!!!
This means that all plugins / modules that need to handle the article id will go in error...
when I turn of KunenaDiscuss the values are correct:
... ["data":protected]=> &array(5) { ["Itemid"]=> string(4) "1811" ["option"]=> string(11) "com_content" ["view"]=> string(7) "article" ["catid"]=> int(87) ["id"]=> int(522) } ...
sharing = caring
Last edit: 9 years 9 months ago by ruud.
9 years 9 months ago - 9 years 9 months ago #183733 by ruud
this method is where it goes wrong:
protected function showTopic(KunenaForumCategory $category, KunenaForumTopic $topic, $link_topic) { if (!$topic->exists()) { $this->debug("showTopic: No messages to render"); return ''; } $this->debug("showTopic: Rendering discussion"); $ordering = $this->params->get('ordering', 1); // 0=ASC, 1=DESC $params = array( 'catid' => $category->id, 'id' => $topic->id, 'limitstart' => (int) !$ordering, 'limit' => $this->params->get('limit', 25), 'filter_order_Dir' => $ordering ? 'desc' : 'asc', 'templatepath' => __DIR__ . '/tmpl' ); ob_start(); KunenaForum::display('topic', 'default', null, $params); $str = ob_get_contents(); ob_end_clean(); return $link_topic . $str; }
before call KunenaForum::display('topic', 'default', null, $params);
the id = 522 after the id = 1020
so in KunenaForum::display the following code sets the article id to topic id
// Render the view. $view->displayLayout($layout, $template);
This is far as I get :(
sharing = caring
9 years 9 months ago #183734 by ruud
This would be a 'work-around' or if reworked a fix. Can somebody have a look?
protected function showTopic(KunenaForumCategory $category, KunenaForumTopic $topic, $link_topic) { if (!$topic->exists()) { $this->debug("showTopic: No messages to render"); return ''; } $this->debug("showTopic: Rendering discussion"); // FIX: Store article's ID $article_id = $this->app->input->get('id'); $ordering = $this->params->get('ordering', 1); // 0=ASC, 1=DESC $params = array( 'catid' => $category->id, 'id' => $topic->id, 'limitstart' => (int) !$ordering, 'limit' => $this->params->get('limit', 25), 'filter_order_Dir' => $ordering ? 'desc' : 'asc', 'templatepath' => __DIR__ . '/tmpl' ); ob_start(); KunenaForum::display('topic', 'default', null, $params); $str = ob_get_contents(); ob_end_clean(); // FIX: Set article's ID back $this->app->input->set('id', $article_id); return $link_topic . $str; }
sharing = caring
9 years 6 months ago #185563 by ruud
fix implemented in Kunena 5.0.8 :)
topic can be set to solved
sharing = caring
