- Thank you received: 13
Question help on error/problem after db import to K7.0.2 (J6.0.3) -> reason old img size
I setup a new Joomla site with a fresh Kunena 7.0.2.
as this should be an update to an old J3 website I saved all Kunena db entries, updated them to the K7 schema and imported ALL
to the new installation.
everything works fine - instead of on error.
when I'm logged in as superuser I can edit or quote each message BUT NOT the first one of a topic.
(the new sample message of the kunena 7 install I can edit)
the CKeditor is opened, but no message appears and the browser console gives me this error:
Uncaught TypeError: can't access property "type", g is null
onTagClose /media/kunena/core/js/ckeditor.js?aa68f1:1298
parse /media/kunena/core/js/ckeditor.js?aa68f1:1295
fromBBCode /media/kunena/core/js/ckeditor.js?aa68f1:1299
b /media/kunena/core/js/ckeditor.js?aa68f1:1303
l /media/kunena/core/js/ckeditor.js?aa68f1:10
and many, many more
I rerun the installation and during the db import I checked this after each single import,
but the import of categories, topics and messages must be present to open an old topic to check for this error.
in the moment I have not yet importet the kunena user tables, but on the installation before it was complete.
I don't know how the kunena script works on edit or reply and what rights or settings are checked during script run
may be some of you knows what is running in the background and can help me please to find if/where I must change
something. (in the db tables)
as far as I see every all other functions work.
btw. switching to private message the editor works fine
- Thank you received: 2538
Did you reinstall Kunena after importing the tables? That might help.I saved all Kunena db entries, updated them to the K7 schema and imported ALL
In the backend, go to Kunena -> Tools, synchronize the users, and let recount the statistics.when I'm logged in as superuser I can edit or quote each message BUT NOT the first one of a topic.
Have you installed the Kunena language files? But there might also be a conflict with a script. Are you using a different Joomla template in your new installation? If so, try using Cassiopeia instead.the CKeditor is opened, but no message appears and the browser console gives me this error:
what do you mean with reinstall kunena?
after my first test I deinstalled kunena and checked mysql where I saw that all kunena tables also has been deleted,
so how I have to reinstall after db import? (just simply run an install over the exicsting one?)
I installed EN and DE language files and use the Allrounder template, but tested also with Casiopaia.
also I have installed KBee kunena template beside the Aurelia (always checked both)
_____________________________________________________________
In the moment I found out this:
1. SCEditor is working fine (so the db import looks without errors)
2. in CKEditor the original message is loaded and present in the hidden textarea (as it should be)
so there must be some js problem within loading ckeditor (Uncaught TypeError: can't access property "type", g is null)
as written: when switching to private message ckeditor enables all buttons
thanks
Taking a look at the documentation https://www.kunena.org/docs/en might also be helpful.
Hello,hi,
and many, many more
Could be a javascript which is corrupted or could be an issue with the language file for Ckeditor which is a javascript file
the most confusing thing is, that CK Editor works well on all messages #2 and up of a topic, but NOT on the first (opening) message.Could be a javascript which is corrupted or could be an issue with the language file for Ckeditor which is a javascript file
(also as written, SK Editor works on ALL)
so what I'm interested in, from the kunena insiders, if there is some db setting in this new versions 6-7 for the opening (first) message,
which I may have missed during my import (also because CK Editor works on the first message of the new created kunena 'welcome' message.
so what is the difference on calling the CK Editor on the top, first message against loading on a following message?
as there are no problems on higher messages the JS files seems to be ok, but as all are minified it is hard to read
thank you
EDIT:
I found out some more details:
it is not the first or second or somthing message, it depends on images.
(as mostly in the first message there are images, I thought just of the first as reason)
it only happens (or better does not
images included as attachment are no problems.
so CK Editor must have a problem with images included the "old way" not using attachment
any ideas ???
