- Thank you received: 1
Kunena 6.4.13 Released
Question Error Class "JFactory" not found after upgrade to Kunena 7.0
0 - Class "JFactory" not found
The Back-End works as it should.
I am on Joomla 6.0.2. The compatibility plugin is enabled.
I opened the Kunena Dashboard after the upgrade and a message confirmed, that the database tables were also updated.
The update process was very strange.
Step 1
Kunena Forum update.kunena.org/6.3/pkg_kunena.xml Site Paket Installed 6.3.10 Available 6.4.8
This update could not be installed. Error «Invalid extension update».
Step 2
I downloaded Kunena 7.0 and tried to install.
Error «You cannot not upgrade Kunena from version 6.3.10, you can only upgrade from version 6.4.5 or higher»
Step 3
I downloaded the latest Kunena pkg_kunena_v6.4.8_2025-12-06 and tried to install.
Error (I do not remember the exact error message).
Step 4
I downloaded the Kunena pkg_kunena_v6.4.5_2025-08-23 and tried to install.
Success.
Step 5
I downloaded Kunena 7.0 and installed it successfully.
When I opened the Front-End, the error message 0 - Class "JFactory" not found was displayed.
I cleared all caches but the error message in the Front-End remains.
So I restored the previously created backup.
My site is working now, but with a fallback to Kunena 6.3.10.
And again the update to Kunena 6.4.8 is being recommended:
With kind regards
Leen
Yes I did.Have you already tried Clear cache in Joomla management section?
Success.
But I will now certainly refrain from upgrading to Kunena 7!
I now notice that you edited your first question slightly
after I asked if you had cleared the Joomla cache.
So now it's difficult to find a good answer, but why don't you test this locally first with a Wamp or Xamp server?
With kind regards
Leen
