Please Read This First:
This category is only for reporting defects with K 3.0.
Do not use this category:
to ask general questions about how to use K 3.0 or to ask when new versions of Kunena will be released;
to ask about other (older) versions of Kunena; or
if you have tried to install K 3.0 on J! 1.5; or
if you installed K 3.0 on a live, production site and you want your site restored to its previous state; or
if this website (
www.kunena.org
) works but works differently to how you expected.
You must include your K 3.0 configuration report; if you do not include your configuration report, your topic may be closed (locked) or deleted without any further warnings from the moderators.
Topics that have been closed (resolved) will be archived and no further discussion on those topics will be allowed.
Question
Page does not reload after sending a post
Ok for my profile in Kunena. I changed template - didn't work.
But then it works as soon as I disable Joomla Plugin in Kunena, but it takes 20 to 25 seconds until I see the sent post, which gives the user the impression that the system doesn't work and he will click "Send" a second time in this time.
Thanks for fast answer. But it is really like this: as soon as I disable Kunena - Joomla Intergration it works (last time even without waiting) - everything seems fine - as soon as I switch on - it doesn't work. So because it works: which problem could appear if I leave this plugin disabled?
And which plugins shall I disable? I have 70 plugins enabled... which type of plugin could it be? I didn't change any plugin or anything else before the problem occured.
Ok - I had Kunena CB Plugin enabled and so it worked well. Also the problem with the 20 seconds waiting time seems to be solved. So the main thing is fixed.
One small question: I have Kunena Latest installed and use it several times with different parameters. In some the date an time is showed and in others it is showed like %14.%b. %2015 - %18:%Mai. Where can I change that? I searched but I didn't found a place to change that.
